Old 02-26-2017, 04:35 PM
L78steve L78steve is offline
Default 12 Bolt Ring and Pinion
I've come across a 12 Bolt Ring And Pinion with a tooth count of 42-13. Would this be a truck 3.23? Came from an Olds GMC dealer.
All I have of the part number is 83729. Numbers prior to are torn off.
Old 02-27-2017, 07:42 PM
Zman1969 Zman1969 is offline
Default Re: 12 Bolt Ring and Pinion
Olds made some 12 bolts that were different/less desirable than Chevy 12 bolts the posi's looked like 8.5's with a S shaped spring. with that said this may be what they are for, just putting this out there
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 02-27-2017, 10:53 PM
Olds had 12 bolt rears but had 10 bolt ring gears installed.
Old 02-28-2017, 12:56 PM
then I'd compare the pinion to a car 12 bolt, the truck pinion is thinner and weaker and a 8.5 10 bolt is larger-use same bearings as car 12 bolt so truck 10 bolts are weaker than the car 12 bolts and 8.5 10 bolts
90 Formula 350
