Old 02-02-2017, 02:52 AM
scuncio's Avatar
scuncio scuncio is offline
Default 68 Camaro rear speaker option
Hi everyone, I am finally adding back the rear speaker option on my Z and don't have an original package tray to use for reference. Would any of you guys be able to send me the dimensions?
Thanks much,
Tony
Old 02-02-2017, 12:52 PM
enio45 enio45 is offline
Default Re: 68 Camaro rear speaker option
tony- is that a single speaker or double setup?
could you not use the speaker hole cutouts in the metal on the package tray?
my Z has a single speaker/fader option from the AM radio
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 02-02-2017, 02:01 PM
scuncio's Avatar
Single speaker, Eddie.... Are you saying the cardboard cutouts match the metal speaker cutout pattern? I wasn't sure if that was necessarily true.
Thanks!
Old 02-02-2017, 04:41 PM
cook_dw's Avatar
cook_dw cook_dw is offline
I laid mine in place before gluing the front down and traced from the trunk side of the holes and opening.. Cant get much closer than that.
Old 02-02-2017, 05:09 PM
scuncio's Avatar
Thanks guys. I couldn't remember if the cardboard cutout was supposed to match the metal cutout.
What did you use to cut the cardboard? Any tips?
Old 02-02-2017, 05:12 PM
cook_dw's Avatar
I used industrial scissors
Old 02-03-2017, 01:37 PM
Tony, after you trace it out I use a box cutter - slow and steady - the speaker cover lays on top and covers any minor defects....
I assume your using a 6x9 speaker and mounts with the studs that slips onto the speaker hole metal slots?
I would not know any other way to mount it??
Do you have one of those rear speaker kits with all the parts in it?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 02-04-2017, 01:05 AM
scuncio's Avatar
Thanks Eddie - that's what I needed to know. Yes, this is an original rear speaker setup with the four screws through the grille.
