Old 01-30-2017, 07:42 PM
Default Olds 350 engine, what is it ?
Hi guys !
I have an engine with the number 395558 2 on the originally goldpainted block. When I google the number I see that it should be a 350 built 1968-70. But when I found the pad with the partial VIN on, it read 34E172286. 3 for Olds, 4 for 1964 or 1974 and E for Linden New Jersey. That #4 doesn´t make sense, so what is wrong here ?
The numbers on the intake reads: Y 411990 B2 BM with 99 (or 66) for date. What do you think, what year is it from ?
Anders Stålklint.
Old 01-30-2017, 08:15 PM
Ryan1969Chevelle's Avatar
Default Re: Olds 350 engine, what is it ?
http://www.442.com/tech/tech.html
http://www.442.com/oldsfaq/ofblk.htm
This will get you started.
HMM.....
Ryan
Old 01-30-2017, 08:16 PM
Yea, I know it looks terrible painted like that !
Moderators, feel free to move this to the Olds-forum. Did not think of it.
Anders Stålklint.
Old 01-30-2017, 10:07 PM
Canuck's Avatar
Canuck Canuck is offline
74, no vin on block pre 68, 64 would be a330. Intake is 73 and up smogger, see EGR boss.
www.vancouverclassiccars.com
Old 01-31-2017, 12:24 AM
The block should be good for any 68-70 SBO project.
What letter and or number is on the heads. (The prominent cast number at the front corner)
68-69 are #5
70 are #6
Then they get lower compression etc.
Old 01-31-2017, 05:18 AM
Thank´s guys,
The heads got a big #8 on them and casting looks like 411 929. Could they be the original heads for a 1974 engine ?
Anders Stålklint.
Old 01-31-2017, 08:01 PM
From 442.com
8 '73 - '76 350 79 411929 Smog heads. Have huge bb-sized 79cc
chambers yielding poor compression
ratios without extremes of
compensation.
Looks like I will need other heads with smaller combustion chambers to get this thing running good.
[img]<<GRAEMLIN_URL>>/burnout.gif[/img]
Anders Stålklint.
Old 01-31-2017, 08:07 PM
442w30 442w30 is offline
For what it's worth, 442.com has a lot of mistakes, although I don't know if this is one of them.
Old 01-31-2017, 08:35 PM
Agree 442.com is not 100%.
Small block Olds castings/cores are low cost, so #5 heads would be easiest (books say 64cc's, actual 68-70cc's) and generally only cost a couple hundred bucks.... then upgrade to W31 valves:-)
Ryan
Old 01-31-2017, 09:26 PM
Thank´s for the advise guys. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Anders Stålklint.
