Old 12-08-2016, 04:08 PM
camaro1 camaro1 is offline
Default couple detail questions on 396 l78 engine
1.what water pump fittings were used in the water pump, I have the slotted ones and hex fittings. Did both sides of the bypass hose(intake and pump) get the slots. Not sure which one goes where. I also have one 5/8 hex seems kind of small. I looked in the assy manual and its not really helpful
2. intake studs and vacuum advance clip, the right side corner is the alt stud then number 4 is the fuel block stud which bolt is the clip for the dist advance line?
Appreciate the help- thanks Rich
