Old 11-21-2016, 04:13 PM
MosportGreen66's Avatar
Default Buick and Chevelle mirrors
Hi Guys, is there a difference between a remote mirror for a 69 Chevelle and the same for a 69 Buick? I know the higher end Buicks mirrors had the logo on it but I am referring only to the more entry level one.
Thanks for your feedback.
Regards,
Old 11-21-2016, 04:31 PM
Woj's Avatar
Woj Woj is offline
Default Re: Buick and Chevelle mirrors
I've pulled a few from 68/69 Buick A bodys in the past and found them to be the same as the A body Chevys. The length of the adjuster cable varies on these.
Phil Woj.
Old 11-21-2016, 06:05 PM
Thanks Phil and sorry we missed eachother @ MCACN
I'll post some pics as they come to me...
Old 11-21-2016, 06:49 PM
Here is what is said to be correct for 1968-1972/Chevelle. Can you guys confirm that to me?
Mirror #1
Old 11-21-2016, 07:07 PM
Mirror #2
Should it have the drain hole on the bottom?
Old 11-21-2016, 08:29 PM
L78steve L78steve is offline
I have a NOS mirror same as your #2. Its in a GM box part number 9822423 but must be the incorrect box. That number comes up as a Bullet mirror.
Hopefully someone can answer this question.
Old 11-21-2016, 09:12 PM
bbbentley's Avatar
Mirror #1 = 70-72 A body, #2 looks like the correct one or close (base should face fwd. and come to a point).
Steve-most probably someone put a "bullet' style on their car and put the old chrome one in the box that the bullet one came in?
FULL OWNER HISTORY
Old 11-21-2016, 09:56 PM
Woj's Avatar
Woj Woj is offline
Here's the one factory installed on my 69 Malibu. Same as #2 above. Which I also believe to be the same for 1968. Can't say for sure on 70 and up.
Phil
Old 11-21-2016, 11:32 PM
68l30's Avatar
68l30 68l30 is offline
FWIW, 68 used a 3 piece mirror. There is a adjusting ring between the mirror head and the mounting arm, this allows it to pivot and fit multiple models depending on which notch is used. This is a one year only mirror.
Example. http://m.ebay.com/itm/172354321219?_...25.m3641.l6368
BIG
Old 11-22-2016, 12:22 AM
you guys are the best... thanks very much!
Phil - the pics were exactly what I needed and I was able to identify an original thanks to them.
Regards,
