Old 11-10-2016, 01:17 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Default Sheared off bolt
Wondering how to come at this to get it out. Or if I do anything at all. Good 660 thermostat housing on a '70 LTI intake...oy
Any ideas? Thanks
Old 11-10-2016, 01:21 PM
L78steve L78steve is offline
Default Re: Sheared off bolt
Simple. The bolt is most likely frozen in the housing not the threads. Let someone that has experience with these situations deal with it.
Old 11-10-2016, 01:54 PM
Tracker1's Avatar
I live on an island off the east coast of Canada - most here want to attack it with a sawzall. it's all on me. If I may reference your signature quote by Faber - "knowledge is good". I need knowledge. Thanks.
Old 11-10-2016, 02:16 PM
Can't you use an Easy Out for that?
Old 11-10-2016, 02:38 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is online now
Can you get the other bolt out, lift the t-stat housing off the intake and then after soaking the threads on the broken bolt with penetrating oil use vise grips to remove it?
Jake Dykstra
Dykstra Motorsports
Old 11-10-2016, 02:47 PM
Tracker1's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: RPOLS3</div><div class="ubbcode-body">Can you get the other bolt out, lift the t-stat housing off the intake and then after soaking the threads on the broken bolt with penetrating oil use vise grips to remove it? </div></div>
No, the sheared off bolt is holding the t-stat housing into the intake
Old 11-10-2016, 02:54 PM
bbbenny bbbenny is offline
Hit it with WD-40 and let it sit for day or two. BBBenny
Thanks Benny
Enjoy; orginal cars,with orginal drivetrains and docs. bblocks are my favorite.
Old 11-10-2016, 03:09 PM
Penetrating oil and heat are your friends in this situation. The heat will allow the aluminum to expand and move away from the bolt.
Old 11-10-2016, 03:15 PM
Tracker1's Avatar
Been doing that for a couple months Benny, yup. I haven't been considering heat or drilling in this situation Jason. But I think I may just have to sacrifice that 660 [img]<<GRAEMLIN_URL>>/frown.gif[/img]
I do have any easy out, just been hesitant to use it...
Old 11-10-2016, 03:47 PM
PxTx's Avatar
PxTx PxTx is offline
Heat, maybe an air hammer with right bit. Get it hot, air hammer stud to transfer vibration. Add favorite lube. Try several times. The heat cycling over time should eventually free the stud from the aluminum housing.
Paul III
