Old 10-29-2016, 01:31 AM
Default Vintage temp sending units
Three senders pictured.
1. AC 275 M. Pin connector with correct terminal end. I believe this is correct for 69 Camaro with idiot light. I also have been told it comes on at 275 degrees f.
2. AC 82B. Spade terminal. No idea. Guessing a sender for a light, but don’t know.
3. AC 12V (which I assume means 12 volt). I removed this from a 72 Chevy truck, C50 with a temperature gauge, so would ASSUME it is a sender for a gauge. Truck is inop, so I don’t know if it was also equipped with a light, but the other head had a pipe plug where the sender would go.
Three questions:
1. Am I correct on number 1?
2. I have also read that all the gauge senders used a threaded post connector. Anyone shed any light on this?
3. And can anyone confirm what numbers 2 and 3 are for and the significance of the numbers?
Thanks in advance.
Old 10-29-2016, 01:57 AM
m22mike's Avatar
m22mike m22mike is offline
Default Re: Vintage temp sending units
Correct on #1, not 100% sure on 2, sounds familiar
Mike
Old 10-29-2016, 02:15 AM
Thanks Mike. I THINK #2 is for a gauge. Came off a 72 C50 with a gauge, and there is one for sale on ebay that says it is for a gauge.
I BELIVE #3 is for a light, but am confused by the 82B.
Old 10-29-2016, 02:27 AM
#2 is for console temp gauge?
Old 10-29-2016, 02:49 AM
m22mike's Avatar
Let me be clear on what I posted. The picture of 2 l have no clue on it's apllication . I was agreing with what Lynn said in his question 2 referring to the threaded post.
Mike
Old 10-29-2016, 04:09 AM
Exactly. That is what I am trying to figure out.
Old 10-29-2016, 04:42 AM
wrench wrench is offline
I guess you meant 257 on #1
Old 10-29-2016, 01:50 PM
Doh!!
Yes, 257.
Old 10-30-2016, 02:19 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
I have #2 on my 69 Camaro big block motor. It's for my console water temp gauge.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
