Old 10-26-2016, 08:55 PM
67BobcatGTO 67BobcatGTO is offline
Default 67 Corvette Parts WANTED
Still looking for a couple tough ones.
1) LH door panel, coupe w/ power windows.
2) Original flame arrestor hose.
If anyone can help, it would be much appreciated!
Thanks
MIke
401-267-0055
[email protected]
Old 10-26-2016, 10:25 PM
hubleyman hubleyman is offline
Default Re: 67 Corvette Parts WANTED
Mike,
I believe you are working on a 435HP car but this ad didn't say...
Just for my own clarification, for the "Flame arrestor hose", are you referring to the S-shaped valve cover to air cleaner base hose that has a flame arrestor inline with it?
If so, I think I still have an extra original off of one of my old 435HP cars...
Is there any difference between '67 versus '68-9? Stamped part numbers, etc.?
I can check my parts stash when I get home after work soon.
Charlie
Charlie (aka: hubleyman)
Old 10-26-2016, 10:29 PM
the427king's Avatar
"Is there any difference between '67 versus '68-9? Stamped part numbers, etc.?"
67 IS COMPLETELY DIFFERENT . 68 has a valve cover elbow that is 90 degrees, 67 takes a stratght flame arestor in the valve cover. therefore the 67 has a 90 bend on both ends. The 68 up is straight on one end
No Fisher priced toys here
Old 10-27-2016, 12:10 AM
Sorry Mike.... no luck in finding the hose (at least not yet).
I found the box that it was supposed to be in, but the hose is not there. I found a picture of the hose actually sitting in that box ('67 style, 90 degree bends on both ends, with the flame arrestor still attached), so I know it was in that box not too long ago.
So I either sold it (which I don't recall doing), or moved it to another location. I may have moved it to save it for my current '67 (which makes sense), but at the moment don't recall where I put it if I did.
Either way, I will keep looking and let you know if and when I find it...
Charlie
Old 11-01-2016, 01:46 AM
Hi Charlie,
Thanks for looking and if you come up with one, I'll happily purchase it from you.
Thanks
MIke
Old 11-02-2016, 02:15 AM
Anyone know any leads I can chase on the door panel??
Old 01-24-2018, 01:49 AM
Hello again Mike...
I'm really late for this party... but thought I should share anyway in case you still had a need.
Just found that hose I was looking for so long ago. Right part in my mind, wrong box in my attic.
Just posted it on Ebay if you are still looking. Or maybe someone else needs one???
Charlie
