Old 10-21-2016, 01:59 PM
DEUCE DEUCE is offline
Default Oil Pan Clearance
Hello, I have a friend who has a 69 Chevelle, that has a oil pan clearance problem, it is rubbing on the front of the frame (crossmember). the Chevelle had a 396 in it and was swapped out for a 454. I believe the engine stands and frame mounts are the same between small block and big block, am I correct?
Thanks for any help, Mike
