Old 09-19-2016, 11:54 PM
lbnaz lbnaz is offline
Yenko Premier Member
Default 1970 Chevelle 12 Bolt Rearend CRW Code
Selling a 12 bolt rearend stamped CRW0331B2 cast dated C230. The one is upside down must of been a bad day at GM. It still has the GM gears as shown, Eaton posi, and has not been modified. It has two different GM drums on it not sure which if any is correct. Has a different pinion flange as shown. Still has the GM metallic pads on one side and no pads only shoes on the other side. The brake line brass block has been removed but still has the original lines on it. The emergency cables are still there and original. It spins freely but has excess pinion play in and out. It will need reset up with a new crush sleeve. I would recommend a complete go through end to end. Price is plus you pay shipping from 85704. I will pallet up and deliver to your choice of terminal so long as they are in Tucson, AZ. Larry 520-349-2337
Old 09-19-2016, 11:57 PM
Default Re: 1970 Chevelle 12 Bolt Rearend CRW Code
more photos
Old 09-20-2016, 01:21 AM
the427king's Avatar
THANKS LARRY.
No Fisher priced toys here
Old 09-20-2016, 03:24 PM
Sold thanks for all the input.
