Old 09-09-2016, 04:13 PM
302moz 302moz is offline
Default late 69 camaro bb motor mounts
Does anyone know if a late Copo 09c uses the same non locking motor mounts ?are they the same as the early ones?Also did the add on brackets come from the factory or dealer installed?I think the brackets are in the assembly manual for the later cars? thanks
Old 09-09-2016, 04:53 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Default Re: late 69 camaro bb motor mounts
Are these what you're calling non-locking? These actually are locking. The driver's side is at least. These are my originals from my 08D 69. I'm not up on COPO, but I can't imagine they'd have any reason to use a different motor mount.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 09-09-2016, 07:44 PM
camaromb camaromb is offline
John,
Your car should have the same motor mounts as HawkX66 shows, with the added steel bracket per assembly manual for late built '69 BB Camaros.
Old 09-09-2016, 07:59 PM
Thanks Mark. Anyone have a pair for sale?
Old 09-13-2016, 11:54 PM
firstgenaddict's Avatar
Those are extremely difficult to find, although I believe they are also found on Caprice line as well.
The drivers side uses a longer bolt with a sleeve which forces the bolt head to the outside of the bracket, I believe the earliest one would see the "safety improvement on line would have been JUNE/JULY.
There is a long thread on the CRG regarding it from 10 years or so ago.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
