Old 09-06-2016, 12:45 AM
travlnz28 travlnz28 is offline
Default Valve Cover ID??
Can somebody identify the application for these? They have drippers.
Old 09-06-2016, 02:23 AM
69L78's Avatar
69L78 69L78 is offline
Default Re: Valve Cover ID??
On the left side or drivers side are there 2 wire clips on top, I cannot see in the pic? It looks like 69 Chevelle but it is missing the sending unit wire clip on the bottom. The pass side is 69 from the position of the short plug wire stand in line with the breather hole
Old 09-06-2016, 11:29 AM
cook_dw's Avatar
cook_dw cook_dw is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 69L78</div><div class="ubbcode-body">On the left side or drivers side are there 2 wire clips on top, I cannot see in the pic? It looks like 69 Chevelle but it is missing the sending unit wire clip on the bottom. The pass side is 69 from the position of the short plug wire stand in line with the breather hole </div></div>
Unless it has the clips on the intake side of the drivers cover for the sending unit going to the intake and assuming the harness was similar as Camaro for the sending unit these would be for a 68 Chevelle as the sending unit wire ran with the alt wiring.
Old 09-06-2016, 01:58 PM
ssl78 ssl78 is offline
I would say they came off a 1967 or earlier since it has a breather cap instead of a vent tube to the air cleaner. The breather cap looks to be original.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 09-06-2016, 03:02 PM
earntaz earntaz is offline
Also -- there is not &quot;dent&quot; in the rear drivers side to clear the booster? ... but I think that came much later ... TAZ
Old 09-06-2016, 06:25 PM
69L78's Avatar
that is not a 67 valve cover with that breather cap, the short wire stand is in line with the breather. 67 covers had the short wire stand in between the breather and the oil fill hole
Old 09-08-2016, 03:31 AM
Kurt S Kurt S is offline
Some info that may help:
http://www.camaros.org/engine.shtml#bbcover
Kurt S - CRG
