Old 09-02-2016, 07:35 PM
earntaz earntaz is offline
Default NIGHTMARE!!
I am still working on my 71’ Nova and just got around to the trunk lid (someone had replaced the original from a donor car) -- I was in the process of working the gaps and alignment. I noticed the stainless trim below the back window was not quite right – so I removed left and right pieces. There is where the fecal matter hit the rotating oscillator!! THE PANEL BELOW THE REAR WINDOW UNDER THE MOLDINGS IS COMPLETE SHOT – LOOKS LIKE RUSTED SWISS CHEESE!! Can anyone here suggest where to get replacement sheet metal for this area? Will I need to pull the perfect headliner out to replace the rusted metal (welding required) around the top of glass (windshield and back glass)? I haven't called 911 yet!!@#$ TAZ [img]<<GRAEMLIN_URL>>/headbang.gif[/img] [img]<<GRAEMLIN_URL>>/no.gif[/img]
Old 09-02-2016, 08:35 PM
bergy's Avatar
bergy bergy is offline
Default Re: NIGHTMARE!!
Is it a VT car? If so, probably a much bigger problem hiding there.
Old 09-02-2016, 08:59 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: bergy</div><div class="ubbcode-body">Is it a VT car? If so, probably a much bigger problem hiding there.</div></div>
VT -- Vermont? No -- North Texas car ... TAZ
Old 09-02-2016, 09:28 PM
Billohio Billohio is offline
I bet bergy meant vinyl top?
Bill
m22mike's Avatar
m22mike m22mike is offline
I am pretty sure he ment vinyl top.
Old 09-02-2016, 11:01 PM
OK -- it did not have a vinyl top ... Thanks ... TAZ
Old 09-03-2016, 01:47 PM
JRSully JRSully is offline
make sure you get the donor metal from a 2 dr Nova, not a 4dr. That metal piece under the rear windshield is different between the 2 body styles
71 Porsche 911 Targa
Old 09-03-2016, 03:50 PM
Yup -- thanks Jim ... TAZ [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 09-04-2016, 01:48 AM
With a welder,and plasma cutter, all things are possible. I've replaced them. Not uncommon on 3rd gen Novas. AMD makes a good replacement piece for that area.
Old 09-04-2016, 01:52 AM
marxjunk marxjunk is offline
engineering degree?
Mark
