Old 09-02-2016, 12:49 AM
ALLZS ALLZS is offline
Default FAST RATIO PITMAN ARM
WHAT IS THE CORRECT CASTING # FOR A PITMAN ARM ON A 1969 CAMARO QUICK RATIO P/S BOX THANKS
Old 09-02-2016, 01:01 AM
Default Re: FAST RATIO PITMAN ARM
I believe the casting # ends in 227
Bill
Old 09-02-2016, 01:55 AM
L78 Fred L78 Fred is offline
Fast Ratio Pitman 3958227 BGMT5
That's the number off my 04C L78 Z11
What else do you need?
Fred
Fred
[email protected]
610-585-4155
WANTED:
Old 09-02-2016, 02:04 AM
SO WAS THE MANUAL & POWER STEERING PITMAN ARM THE SAME NUMBER I HAVE SEEN CASTING #3953227 ARMS BUT THEY ALL SAY FOR MANUAL STEERING
Old 09-02-2016, 02:16 AM
Mine was a PS car with F41 suspension
I will have to check a Manual box/pitman arm I have marked from a Z years ago
Fred
[email protected]
610-585-4155
WANTED:
Old 09-02-2016, 08:23 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
From CRG (http://www.camaros.org/suspen.shtml#steer)
"Note that the same pitman arm forgings were used for both manual and power steering, but the splined holes for the attachment to the steering box were different sizes."
Tim in NSW, Australia
Old 09-02-2016, 11:47 AM
IS IT A SPLINE COUNT OR A SIZE IF SO WHAT IS THE SIZE I WOULD BE LOOKING FOR ? THANKS
Old 09-03-2016, 01:03 AM
ZLP955's Avatar
Not sure, never had one of each side by side to compare difference. My car has the manual steering box but I haven't pulled the pitman arm yet.
I have an idea that the output shaft on a PS box is a larger diameter than on the manual version (in the same was as the drag link is a larger diameter with PS), but hopefully someone else can confirm and answer your Q.
Old 09-03-2016, 08:42 AM
ZLP955's Avatar
Further to previous post, just looked at a manual box that has a 227 pitman on it, and the arm has a 'M' stamped on it near the splined hole. Wonder if they have 'M' or 'P' to denote application?
