Old 08-28-2016, 07:56 PM
Spooky's Avatar
Spooky Spooky is offline
Default First Gen Camaro/Firebird NOS Rocker Panels
Here is a pair of left and right OLD GM NOS galvanized Outer rocker panels for 67-69 Camaro/ Firebird coupes.
These would be a must on any high end resto for that special car. One is missing it's gm sticker but the other one has it still with the remnants of the tape that was holding the pick tag. They both have gm numbers stamped in them (not the actual part numbers, maybe batch?) and you can even see the ink stamp from the steel roll in 2 places. These are almost mint. They are USA steel and Heavy!!! The only small defects I could find are the end of one, the end flap was tweeked out (i didn't want to mess with it), 1 spot (maybe 2) of discoloring in the galvanizing and one very small dent on the inner to outer seam. Just wanted to point out everything. Some of the pics they look wavy. They are not. The color changing of the Galv coating makes it seem that way in my crappy pics. I added as many pics as I would want to see If I were buying. I will take more if needed, with a better camera.
Scott
69 Camaro RS/SS X22 4speed NOM but working on something special
69 Camaro x11 355 crossram m22 12 bolt 3.73's
Old 09-05-2016, 07:56 PM
Spooky's Avatar
Default Re: First Gen Camaro/Firebird NOS Rocker Panels
Carlisle is just around the corner if anybody need these ultra rare pieces. They could be the last set around.....
Scott
