Old 08-15-2016, 09:44 PM
Zman1969 Zman1969 is offline
Default 69 Nova SS original master/booster #s??
Looking for master and booster #s 69 Nova SS? any survivors out there? Wilma?
Thanks
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 08-16-2016, 12:38 PM
Default Re: 69 Nova SS original master/booster #s??
We will need build date on the car for this request...booster and master cylinder are both dated items. You want survivor/driver quality parts correct??
-wilma
Old 08-16-2016, 01:33 PM
car is a 09C of 1968 was looking for the part, casting numbers but hey if you have the parts I'm looking
thanks
90 Formula 350
Old 08-16-2016, 02:20 PM
Sorry, I thought you meant a 'numbers matching' 1969 car.
The booster would be a 9204...master cylinder would have the US code stamped on the front. Since you have a very early car you would be looking for dates in the Aug to very early Sept time frame. Not sure what I have in the parts bin, but I will check. Camaro shared these parts as well...so it is likely someone here may be able to help. If the date isn't critical, then the process should be easier. As for the date stamp on the booster for your car...something in the 210-250 range would be ideal.
There are times when early vehicles carry over parts from the prior year...but in this case it is doubtful since the 68 disc brake Novas had the 4 piston calipers, so I would imagine there would be all new components for 69.
-wilma
Old 08-16-2016, 06:06 PM
OK thanks Tom if your looking, I can also use one of these-
nova 396 shrould bracket needed
Thanks for the info!
90 Formula 350
