Old 07-10-2016, 06:40 PM
bbbentley's Avatar
Default BB 67-9 Camaro Headers old ones
Picked up a set of Super Stock old school pipes. 2 1/8 slide in collector. Can someone lend a hand IDing these? I cannot remember every header manufacturer, but I have looked up the following-Hooker, Doug's, Hedman Hedders, Jardine, Stahl. Is there some other brand I am forgetting? Oops, Doug Thorley is another. Does someone recognize these by style or manufacturer? Thanks, sYc.
FULL OWNER HISTORY
Old 07-10-2016, 07:26 PM
scuncio's Avatar
scuncio scuncio is offline
Default Re: BB 67-9 Camaro Headers old ones
Look for codes stamped into the engine flange and let us know.
Old 07-11-2016, 02:45 AM
bbbentley's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: scuncio</div><div class="ubbcode-body">Look for codes stamped into the engine flange and let us know. </div></div>
I have looked and looked and looked again at the flanges and collectors and do not see any markings or numbers, so? But thanks Tony for your help.
FULL OWNER HISTORY
Old 07-11-2016, 01:33 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Maybe custom?
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 07-12-2016, 01:26 AM
scuncio's Avatar
I was going to say the flanges looked a little like Kustom headers...but those would have had the model stamped into the outer surface of the flanges.
Old 07-12-2016, 12:45 PM
HawkX66's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: scuncio</div><div class="ubbcode-body">I was going to say the flanges looked a little like Kustom headers...but those would have had the model stamped into the outer surface of the flanges. </div></div>
I actually meant custom, not Kustom. I thought maybe they were welded up by someone and not a manufacturer.
-Dave
Semper Fi!
Old 07-12-2016, 08:48 PM
earntaz earntaz is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: HawkX66</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: scuncio</div><div class="ubbcode-body">I was going to say the flanges looked a little like Kustom headers...but those would have had the model stamped into the outer surface of the flanges. </div></div>
I actually meant custom, not Kustom. I thought maybe they were welded up by someone and not a manufacturer.</div></div>
Have to agree -- with all the weld joints it appears someone had alot of time on their hands ... still look good. TAZ
Old 07-13-2016, 04:58 AM
Day2_69Z Day2_69Z is offline
With the short down throws on drivers side and the rewelds, modifications.... I'd say a welded up set as well.....the flanges were readily available then and are still today..... #'s are usually stamped during or after assembly....
The welds too.....aren't anything you'd see on a Header Shops build.....definable stick welding at home.
