Old 06-22-2016, 05:16 PM
XXXGoldL34M20's Avatar
Default Proper name for Multiplex Radio Part 67-68 Camaro
I have this Multiplex 9 Pin part in the Blue Circles.
What is it called and what is the value for something like this?
Old 06-22-2016, 05:25 PM
Default Re: Proper name for Multiplex Radio Part 67-68 Camaro
Only found this link right here on sYc.
He says it plugs in when the Multiplex was not used but it came from a Multiplex unit? [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
https://www.yenko.net/ubbthreads/ubbt...-fm-9-pin-plug
Old 06-22-2016, 05:29 PM
I call it the multiplex eliminator plug. It plugs into the radio and makes it work as a mono radio. The radio will not work without this plug or a multiplex installed. They came on all Chevy AM/FM radios except Corvette from 1965-1969. $75-$100 would be fair for a tested working one.
Old 06-22-2016, 05:30 PM
marxjunk marxjunk is offline
also called a radio shunt
Mark
Old 06-22-2016, 05:41 PM
Thank You Guys.
Will have to sell it &quot;As Is&quot; because I have no idea on how to test this.
Old 06-22-2016, 06:25 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: XXXBlackLs6M22</div><div class="ubbcode-body">Only found this link right here on sYc.
https://www.yenko.net/ubbthreads/ubbt...-fm-9-pin-plug </div></div>
Now I get it, this has a part to make the Radio work without the Multiplex Option in a mono tone. If you ordered the Multiplex radio this would have to come off in order for the Multiplex AM/FM to work in Stereo. Thanks P.J.
Old 06-22-2016, 06:58 PM
earntaz earntaz is offline
Appears to be a fancy name for a &quot;jumper&quot; ...
Old 06-22-2016, 06:59 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SuperNovaSS</div><div class="ubbcode-body">I call it the multiplex eliminator plug. It plugs into the radio and makes it work as a mono radio. The radio will not work without this plug or a multiplex installed. They came on all Chevy AM/FM radios except Corvette from 1965-1969. $75-$100 would be fair for a tested working one.
Jason </div></div>
Jason I was told 1965 and 1966 had a 12 pin MPX Eliminator and they started using this 9 pin plug for 1967 to 1969 Chevrolet Except Corvette.
Old 06-22-2016, 07:02 PM
Yes, 67 and earlier radios use a 12 pin plug but I believe they use this same jumper.
