Old 05-28-2016, 05:08 PM
XXXGoldL34M20's Avatar
Default Help In Identifing These Parts Please
I picked up a large consignment of parts to sell which are mostly 1970 Chevelle Parts but some parts are 1967 to 1969 Camaro parts which I do not recognize as I mainly sell Chevelle stuff.
Before I put these for sale on the sYc "Buy-Sell" I would like to know what each part Is.
Help is much appreciated.
Thank You
Old 05-28-2016, 05:46 PM
ssl78 ssl78 is offline
Default Re: Help In Identifing These Parts Please
Bottom pieces are rear spring hanger shackle plates and bolts. upper left starter support brackets the two rubber boots are after market tie rod boots. That oval metal plate is Camaro or firebird rear upper shck mount plate
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 05-28-2016, 06:16 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ssl78</div><div class="ubbcode-body">Bottom pieces are rear spring hanger shackle plates and bolts. upper left starter support brackets the two rubber boots are after market tie rod boots. That oval metal plate is Camaro or firebird rear upper shck mount plate </div></div>
Thank You John [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 05-28-2016, 06:20 PM
One Starter Bracket Brace is longer then the other two.
Is the shorter one and long one a Small block Vs. Big block variation and which is which.
Also that Engine lift bracket must be for a small block as I know what the Big block one looks like.
