Old 05-23-2016, 05:40 AM
Kurt S Kurt S is offline
Default Carb gaskets
I picked up a bad batch of gas last year. Next time I went to start the car, the Holley leaked *everywhere*. It would slowly stop as the gaskets swelled, but ugh...
Is there any gaskets sets that are more resistant to the ethanol (I assume that was the cause) or can this happen again after the rebuild?
Thanks!
Kurt S - CRG
Old 05-23-2016, 12:01 PM
Default Re: Carb gaskets
I would PM Eric Jackson and/or call Holley direct.
Holley: 1-866-464-6553
Old 05-23-2016, 01:29 PM
earntaz earntaz is offline
Eric is your man -- but I would suggest the "blue" bowl and metering plate gaskets ... not the cork (which shrink over time if not kept wet). TAZ
Old 05-23-2016, 01:34 PM
Two suggestions...find some ethanol free fuel...and call Eric.
Good luck...
wilma
Old 05-23-2016, 01:40 PM
correct Tom.
Old 05-23-2016, 01:49 PM
bigsixman bigsixman is offline
I have had no problems with the Holley blue gaskets and MN has had ethanol in the fuel for many years. I also use Klotz fuel conditioner every time that I fuel the car and it protects the rubber items in the fuel system.
69 camaro X11, 56,000 miles, original HO paint
67 camaro SS/RS, Butternut yellow, bench, fold down
Old 05-23-2016, 01:56 PM
Eric rebuilt my Holley many years ago with the correct cork gaskets and I too run ethanol gas.
I keep the engine moving weekly &amp; so far no leaks.. [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Old 05-23-2016, 04:05 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mr70</div><div class="ubbcode-body">Eric rebuilt my Holley many years ago with the correct cork gaskets and I too run ethanol gas.
I keep the engine moving weekly &amp; so far no leaks.. [img]<<GRAEMLIN_URL>>/dunno.gif[/img]</div></div>
Yep -- the key is to not let the cork gaskets dry out ... if the fuel evaporates cuz' you're not starting the engine everyweek, the gaskets will leak ... TAZ
Old 05-25-2016, 05:14 AM
Thanks! That answers the question. The car sits all winter.
It was interesting that I've had no issues for years, then one tank of gas changed all that.....
Kurt S - CRG
Old 05-25-2016, 10:12 AM
ds1 ds1 is offline
Kurt the Green accelerator pumps are way better than the old type and either Blue or Red non stick gaskets are the best.
1967 Camaro conv (first car)
1969 Camaro street car
1967 Super Stock SS/JA Joe Scott car
