Old 05-09-2016, 04:05 PM
Default Disc Brake Caliper - bleeder screws
Any advice on getting the old bleeder screws out? They are now perfectly rounded, and simply don't want to budge!
Old 05-09-2016, 04:15 PM
Rixls6 Rixls6 is offline
Default Re: Disc Brake Caliper - bleeder screws
Don't know if the flame wrench will warp the calipers beyond a rebuild, but heating the area where the bleeder screws are until red, generally allows the bleeder to unscrew with a vice grip.
Rick
Don't text and drive.
Old 05-09-2016, 05:24 PM
jasonL78 jasonL78 is offline
hit the area with a torch it won't take much to loosen them with vise grips.
Looking for the next project.
Old 05-09-2016, 05:26 PM
A propane torch will get them plenty hot and will not hurt the caliper. I have to do this on almost every set of used ones I buy. Like Rick says, a vice grip and some heat and you are good to go but be very careful of the now very hot brake fluid.
Old 05-09-2016, 07:09 PM
Thanks all, the calipers are totally empty and blasted so I can rebuild them - so no boiling brake fluid (this time!).
Old 05-09-2016, 10:40 PM
Spooky's Avatar
Spooky Spooky is offline
We usually tap them with a hammer down to loosen the rust, it has had years of pushing up against the threads and the hammer puts them down. It is a tip my brother showed me. He is a Jeep master tech. We also swear by Mopar rust penetrant. The stuff seems like magic.
Scott
69 Camaro RS/SS X22 4speed NOM but working on something special
69 Camaro x11 355 crossram m22 12 bolt 3.73's
