Old 05-05-2016, 11:11 PM
Enoch Enoch is offline
Banned
Default Help ID 67 Z28 breather hose????
I need help in trying to identify this part. I believe it to be an air cleaner breather hose from a 67 Z28. But I don't know for sure. Original GM stampings embossed into it depressed into the hose and K stamping into the hose too along with alligator skin and white ink markings. Thanks in advance rich.
Old 05-06-2016, 12:04 AM
marxjunk marxjunk is offline
Default Re: Help ID 67 Z28 breather hose????
Looks like 70 big block to me...but I'm no expert.when was researching some stuff I had I remember seeing a post on a camaro site..in 70 the nipple off the air cleaner points to the heater box and the hose was the same size basically..and small blocks there was a huge taper down for the valve cover
It's been repoped...look on ebay
Mark
Old 05-06-2016, 07:03 PM
Banned
Mark, thank you for taking the time to respond. I had checked out the 70 a big block breatherhose. This one could be used for that but you would have to cut part of the one end off. The 70 big block hose has equal legs on either side of the bend this hose the one leg is twice as long as the other just like the 67 Z28 breatherhose. That's why I was thinking that. Thanks again
Old 05-07-2016, 07:56 AM
I wasn't sure.. It just popped into my mind
Mark
Old 05-09-2016, 03:39 PM
SS69chevelle SS69chevelle is offline
Rich, could be a 69 BBC breather hose depending on the length. looks like it has the correct curve. they curse slightly to the front to hook to the closed air cleaner from the valve cover.
Andy
Team Chevelle #3135
ACES #08305
1969 Chevelle Trim Tag Research (On-going)
Old 05-10-2016, 04:23 PM
Banned
Andy, thanks would you happen to have a picture of an original?
Old 05-11-2016, 04:25 PM
Banned
Thanks to Andy and a picture posted by Woj on Team Chevelle I think we have a winner. 69 396-325 hp
snorkel air cleaner breatherhose
