Old 04-15-2016, 11:03 AM
69L78's Avatar
69L78 69L78 is offline
Default MR Gasket Shifter Handle
I am looking for an original shifter handle or ball, I am not sure what is correct for this vintage shifter. The threads are 1/2"
Old 04-15-2016, 04:31 PM
68l30's Avatar
68l30 68l30 is offline
Default Re: MR Gasket Shifter Handle
T-Handle w/ Mr. Gasket logo is correct. I can take a pic later.
BIG
Old 04-15-2016, 09:50 PM
Damien Damien is offline
One at least on eBay.
http://www.ebay.com.au/itm/VINTAGE-M...QAAOSwq19XCnrO
1969 SS 396/350 Chevelle
Old 04-15-2016, 10:55 PM
67 Nova Boy's Avatar
Handle
Old 04-16-2016, 12:16 AM
69L78's Avatar
Thanks for the help
Old 04-19-2016, 08:16 PM
whitetop whitetop is offline
69l78 You have the very earliest version of the Vertical gate shifter===cool i.e.e round pin dowel rod for the pull up handle.
In hard use they would break at that spot so later versions of the shifter had a stronger triangulated piece.
Old 04-19-2016, 08:42 PM
68l30's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: whitetop</div><div class="ubbcode-body">69l78 You have the very earliest version of the Vertical gate shifter===cool i.e.e round pin dowel rod for the pull up handle.
In hard use they would break at that spot so later versions of the shifter had a stronger triangulated piece. </div></div>
Bingo!
That's why I only have the T handle and the pull up handle left....I sent it to Hurst for a rebuild and they gave me a new RamRod. Also helped that I knew someone at Hurst.. [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
BIG
