Old 04-13-2016, 10:21 PM
68moz28rs's Avatar
68moz28rs 68moz28rs is offline
Default 69 Chevelle, Camaro, Multiplex Blue light stereo
69 Am/fm blue light stereo with amp. Needs to be restored and serviced. 91BFM2 stereo. Letter B indicates Chevelle but Chevelle audio equipment was often used on other cars from the factory. I've heard B means default as well but I don't know the codes like that. Radio was tested and works. Asking $850. Open to offers. PM for more pictures or questions.
Thanks, Brandon.
68 Camaro 302 Z/28 Rally Sport
68 Camaro Convertible w/427
68 Camaro Drag Car
67 Camaro Royal Plum RS/SS
67 Camaro Convertible 327 RS
92 Corvette Convertible Quasar Blue white top
http://www.ebay.com/sch/usa-1musclec...pg=&_from=
Old 04-13-2016, 11:43 PM
jl8z28 jl8z28 is offline
Default Re: 69 Chevelle, Camaro, Multiplex Blue light stereo
I think there is somebody over at team Chevelle looking for one
Old 04-14-2016, 02:06 AM
68moz28rs's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: jl8z28</div><div class="ubbcode-body">I think there is somebody over at team Chevelle looking for one</div></div>
Do you know his username? Any help would be appreciated
Thanks, Brandon
68 Camaro Drag Car
http://www.ebay.com/sch/usa-1musclec...pg=&amp;_from=
Old 04-14-2016, 03:17 AM
aawtech aawtech is offline
That is an Impala unit, not a Chevelle unit. A is Chevelle, B is Impala. The multiplexer is positively Impala only. Won't work in a Chevelle or Camaro. The bracket is welded to the case and won't work in the other models. The radios were all coded for Passenger(B), the multiplexers were unique per model.
Donny
Old 04-14-2016, 03:22 AM
68moz28rs's Avatar
The radio is coded B for passenger. The multiplex has no tag as it came off.
68 Camaro Drag Car
Old 04-14-2016, 03:39 AM
68moz28rs's Avatar
The code 91BFM2 was used in Camaros and Chevelles as well. This came out of a Chevelle so I know it fits.
Thanks, Brandon
68 Camaro Drag Car
Old 04-14-2016, 04:03 AM
Umm, the bracket is screwed to the case, not welded. The amp is the same as Camaro and Chevelle. The bracket is for Impala but can be changed.
Old 04-14-2016, 04:15 PM
68moz28rs's Avatar
So The radio can be used for basically any of the cars that came with it they just may or may not take a different bracket. Which is what I originally thought? Or am I wrong?
Brandon
68 Camaro Drag Car
Old 04-14-2016, 04:32 PM
Brandon,
That is correct. The radio and amp will fit Camaro, Chevelle, and Impala. The correct bracket just needs to be screws to the amp.
Old 04-15-2016, 05:33 AM
16 Grand Sedan 16 Grand Sedan is offline
As I recall that amp with the bolt on 90 degree bracket is Impala. It was mounted on the main pedal bracket thus close to the radio.
The Camaro amp was installed above the glove box between the cowl and dash area. The Camaro bracket was originally welded on. At one time there was a repo bracket available to convert the Impala for a Camaro.
However, the cable/wire on the Impala amp is not nearly long enough to reach over to the glove box location. Perhaps a board stretcher from a local carpenter will help.[img]<<GRAEMLIN_URL>>/haha.gif[/img]
