Old 04-10-2016, 01:17 AM
302moz 302moz is offline
Default two bolt BB vs four bolt
How can you tell the difference in a real four bolt block (1969 512 )from a two changed to a four?the oil cooler and oil pressure holes are bigger in a four ,but are easy to change. Any other ways to know for sure its a real four bolt???thanks John any pictures would be very helpful
Old 04-10-2016, 04:49 PM
ssl78 ssl78 is offline
Default Re: two bolt BB vs four bolt
They always do not put in the valve relief in the cylinder
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 04-10-2016, 05:26 PM
thanks for the info John. Any other things?Are the outer holes for the for bolt caps counter sunk?
Old 04-10-2016, 07:23 PM
bbbentley's Avatar
I recall this Youtube video tutorial you need to watch: https://www.youtube.com/watch?v=tlizhIURezE
FULL OWNER HISTORY
Old 04-10-2016, 10:09 PM
great video.Thanks for the info
Old 04-11-2016, 05:38 AM
the427king's Avatar
"They always do not put in the valve relief in the cylinder".......John, you are right on the valve reliefs . He also left out 3-4 more signs,with one being the tell all , especially for such a long video . Seemed to focus too much on the line hone,which is really ireelvant in that most blocks get that regardless if they are converted or not.
No Fisher priced toys here
Old 04-11-2016, 02:10 PM
so what are the 3 or 4 more signs?thanks
Old 04-21-2016, 07:33 PM
69L72RS 69L72RS is offline
I know of at least three builders who broach cut the caps and use a vibratory method to "seat" the caps to the blocks, prior to honing, so that is not a guarantee.
Just my $.02.
Old 04-25-2016, 09:22 PM
Zman1969 Zman1969 is offline
I thought the oil plugs along the side of the block were a little larger on the 4 bolts - IIRC
that and the 1" oil plug on the side - I know now that the later 4 bolts are not made that way anymore maybe because the oil filter adapter coolers that became avail in the '80s? I have a 90 or so LS6 454 4 bolt crate engine that doesn't have the big plug
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 04-25-2016, 09:35 PM
VintageMusclecar's Avatar
The later blocks (I have a "445" block) aren't drilled for the large hole since the trucks they came in usually had an aux. oil cooler adapter sandwiched in between the block and the oil filter. There was no longer a need to drill the block for the larger fitting.
