Old 03-18-2016, 06:38 PM
Default 1969 Camaro subframe bracket
Does anyone reproduce this bracket? Mine is dented. Also open to a used one if someone has one. Thanks
Old 03-19-2016, 12:30 AM
DEUCE DEUCE is offline
Default Re: 1969 Camaro subframe bracket
You could heat it and straighten, I have had good luck in the past.
Mike
Old 03-19-2016, 01:37 AM
Plowman's Avatar
Plowman Plowman is offline
Take the bracket it and straighten the bracket[you can it get straighten in a vice off the subframe easy]. Then weld it back on. Also you can weld up the subframe,at the crack, on the lower left of the picture.
