Old 03-15-2016, 08:00 PM
Geoff Padgett Geoff Padgett is offline
Default Spring cleaning sale, misc stuff
It is time for spring cleaning, I have tried to attach photos but I think they are too big for the site, if you see anything on the attached list that you are interested in please e-mail and I will send you a photo if you send me your address. Plus shipping and I will combine shipping if you buy more that one item. Thanks, Geoff. Most of all items are GM not repop
69-72 Big block lower alternator stud and bracket 40.
Rear sway bar shims (3) 20.
Big block Balancer bolt and washer W/ hour glass headmarkings 20.
Bucket seat back release 69-72 15.
Dash clock nuts (3) 5. Ea.
Positive terminal block W/ attachment bolt and nut(mounted on rad support next to battery-fusable link to battery) (2) 15.
Inner and outer tie rod boots original (2) 15. Ea.
NOS wheel well screws (33) 40.
Rear lower Shock and nuts (2) sets 20.ea set
68-72 front lower windshield tabs super clean set (1) set 40.
70 SS clock-does work, clean face 20.
68-72 front eibach 2’’ lowered springs 50. Pair
Gold anodized moroso valve cover wing nuts big block 50.
Square end clamps assortment 3. Ea.
Big block mini high torque starter, low miles works great 75.
Big block comp cams roller tip rockers (1) set 75.
Big block 3/3 hardened tip push rods (1) set 75.
Big block 3/8 push rod guides- need 2 more to make a complete set 40.
Pass side door mirror 60.
Electric trunk release with an over the counter release button with chrome surround 75.
Cranberry red 1970 L-S6 hardtop
