Old 03-01-2016, 05:53 PM
Caseys69 Caseys69 is offline
Default L78 Piston Options
Im going to be assembling a 69 L78 6223 crank, 272 396 block, 3/8 dimple rods. What are my options for pistons? If im correct, the L78 was 11-1. I will be using 840 heads. The block is STD bore
Old 03-01-2016, 07:31 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Default Re: L78 Piston Options
Speed Pro L2242F but not sure if they offer a standard bore piston or IIRC Eric offers up some alternatives.
https://www.yenko.net/ubbthreads/ubbthrea...isto#Post591539
Old 03-01-2016, 08:11 PM
VintageMusclecar's Avatar
Casey;
Your options are wide-open depending on your needs. Give me a call if you'd like and I'll see what I can do.
Eric
Old 03-02-2016, 12:40 AM
the427king's Avatar
pistons
No Fisher priced toys here
Old 03-02-2016, 01:01 AM
PxTx's Avatar
PxTx PxTx is offline
I'd vote for getting that standard bore straight and getting a custom set of pistons from Eric.
Might end up .010 over but I just can't imagine settling for a loose fitting stock high compression piston that is detonation prone (questionable on pump gas), way too heavy and the combo of virgin bore and stock pistons probably will not yield the best ring seal.
Paul III
Old 03-02-2016, 02:00 PM
Eric, ill be calling you for some advise
Old 03-02-2016, 03:21 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Caseys69</div><div class="ubbcode-body">Eric, ill be calling you for some advise </div></div>
That is one call that will be well worth the time invested [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
