Old 02-28-2016, 05:08 PM
Default special fuel pump for retro roller?
I just built a mild 350 with a retro roller hydraulic cam. Bought the special fuel pump push rod for roller cam.
I re-used the fuel pump that was on the previous engine as it looked pretty new, and functioned well on the two barrel carb that was on that engine. No leaks and no flooding.
Fired up the new engine and after a few seconds gas just pours out the top of the carb (Q-jet. Removed the carb assuming I had some trash in the needle and seat. All looked good, so put it back together. Just put a pressure tester on the fuel pump and immediately went to 10 psi just cranking. Didn't even bother to start it, as 10 psi is obviously way too much.
My options are: try another fuel pump (but I hate throwing parts at something), install an in line regulator (have never needed a regulator on a stock type fuel pump), or ditch the pump and rod and install a low psi electric pump. If the correct mechanical pump would work, that is my preference.
Anyone else ever encounter something like this?
