Old 02-21-2016, 04:25 PM
lbnaz lbnaz is offline
Default LS-7 454 Blown Head Gasket Motor Value
Hello, just trying to get an idea as to the value of a GM crate motor LS-7 that has a blown head gasket on drivers side. Got oil in radiator and and water cylinders. Was only ran a few miles after it was discovered. Original long block but after market intake. Looking to buy it possibly. Thanks.
Old 02-21-2016, 05:07 PM
luzl78 luzl78 is offline
Default Re: LS-7 454 Blown Head Gasket Motor Value
Is it a 72 or 73 motor? I'd say 5,000-6,000
Old 02-21-2016, 06:16 PM
Hello, no its a 75 motor. Appears to have been apart before the rods are numbered, not GM gaskets, its still standard bore with all the original parts including the cam. It was in a Chevelle that just sold at BJ a few weeks ago that never ran right. Being replaced with a street able motor. Thanks.
Old 03-03-2016, 07:42 PM
The rods would have been numbered from the factory,and as far as I know,the LS-7 was sold as a short block with no tin,so non GM gaskets would be the norm. Guys still have them out there brand new for under 3 grand,my friend just bought an brand new LS-7 short block still in the cosmoline for $1900. That was a 1985 engine. Until you fix it,it isn't worth any more then the sum of the parts. Nothing from a 1972 LS-7 has any numbers matching relationship to a rare or value able car. If you fix it and get it to the point where it can be a good running long block,it might be worth $2500 as a used engine.
