Old 02-15-2016, 04:49 PM
ted ted is offline
Default CE 060XXX TO318 9654 block . . .
Should the above CE 1970 block have 4 bolt main caps numbered #964, or 2 bolt main caps number coded #362?
This block is also stamped G9 9 which means what exactly?
Thanks in advance gennelmen!
Ted
Old 02-16-2016, 03:22 AM
bbbentley's Avatar
Default Re: CE 060XXX TO318 9654 block . . .
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ted</div><div class="ubbcode-body">Should the above CE 1970 block have 4 bolt main caps numbered #964, or 2 bolt main caps number coded #362?
</div></div>
Will probably need to put up some pics of both, stamp (G9 9) to see where it is located and oil filter area of block to determine if 2 or 4 bolt.
Looks like it was assembled on March 18th. The G 9 9 where is this stamped? Generally, G would indicate July and 1st 9= day of month and other 9= year. But without seeing, it is impossible to say at this point.
FULL OWNER HISTORY
Old 02-16-2016, 02:20 PM
Are you sure the casting number is not ....854???
If so, this block was produced in both 2 bolt and 4 bolt main depending on the use.
wilma
Old 02-16-2016, 03:36 PM
ted ted is offline
Number is 854 Wilma.. I have it noted that G9 9 is on rear of block deck. Near oil filter mount is Hi Perf Pass
Under timing cover is a G7 ..
Ledge where starter bolts up to is a T 089 . Do not remember if this is 'scrawled' or punched.
Will have to wait to see oil filter area, maybe a month or two. What am I looking for here exactly?
Again, I will get back as soon as I can on the above 854 CE block.
Thanks for the help!
Ted in Montreal
Old 02-16-2016, 03:42 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Ted
</div></div>G 9 9 is a date code. July 9, 1969. So it's a 69 cast block. The &quot;TO318&quot; is actually &quot;T0318.&quot; Zero, not O. Stands for Tonowanda built March 18. More than likely your &quot;6&quot; should be an &quot;8&quot; for your &quot;9654&quot;. I'd double check your stamp pad. March is way too far out for a July block. Might be normal for a CE block though? I don't know. Maybe post some pics?
Does it look like the below pic? Big block 402?
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 02-16-2016, 04:48 PM
ted ted is offline
Thanks for the reply Sgt Hawk. I have pics (couple) of this block, but, I need an E-mail address to send 'em to.
If you could help and then post them on to the Board, I will envoy the photos later..
Ted in (freezing rain) Montreal
Old 02-16-2016, 05:34 PM
HawkX66's Avatar
No problem. I'll pm you my email.
-Dave
Semper Fi!
Old 02-22-2016, 02:20 PM
HawkX66's Avatar
I just got your email. Here you go Ted. Sure looks like the T0318 ET is re-stamped to me, but I don't have a lot of experience with CE blocks.
-Dave
Semper Fi!
Old 02-22-2016, 04:24 PM
SS69chevelle SS69chevelle is offline
That is a restamp without a doubt. The CE block assembly code is located on the starter pad and this one is T089 as seen in the pic. Aug 1969 is when it was assembled and the block was cast July 9 1969. make sure you check the bore since the 854 block was used for the 402 vs 396 in 70. Some late 69 854 blocks were bored to 396 and in 70 they received the C proceeding the engine suffix code indicating that they were the 2nd design 400 CID engine (402), pic attached of the note from a parts manual about the pistons.
Andy
Team Chevelle #3135
ACES #08305
1969 Chevelle Trim Tag Research (On-going)
Old 02-22-2016, 04:33 PM
HawkX66's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SS69chevelle</div><div class="ubbcode-body">Some late 69 854 blocks were bored to 396 and in 70 they received the C proceeding the engine suffix code indicating that they were the 2nd design 400 CID engine (402), pic attached of the note from a parts manual about the pistons.
</div></div>The &quot;C&quot; prefix hit the 69 Camaros for August 69 bodies. Any &quot;C&quot; prefix is a 402. My born with motor was cast on July 23, 69 and assembled July 28th for a August 22 body.
-Dave
Semper Fi!
