Old 02-04-2016, 02:57 AM
Crossbreed383 Crossbreed383 is offline
Default 1968 BB Nova Questions
Hello all, I APOLOGIZE FOR THE DUMB QUESTIONS I AM ABOUT TO ASK IN ADVANCE!!!!
Just bought a 1968 Nova
Original 6cyl car,3 speed manual
Going to go with a (396-375hp) BB clone style build
I have a 11.5-1 comp 427 I'm building, using Vortec Pro heavily ported 781's, solid roller,163 manifold, Holley carb,etc,, and M20 trans, along with a 12 bolt rear for the project.
Let me start by saying I cant afford to go to the extreme of buying date coded parts,etc
Looking for a nice build ,nicely detailed vehicle, I wont be scared to drive and that APPEARS CORRECT to the average spectator
Questions I have are:
1-Does anyone make a manual front disc brake setup that looks OEM? Assume it will have to be 69' and up rotor type do to no 2 piece rotors?
2-Would this type car normally be a multi-leaf setup in rear?
3-What number of spoke fan blade would it have?
4-I may go to 69' accessory, as I like the look of the long water pump brackets better, and if I do, does the crank have a double groove pulley and single water pump groove pulley with manual steering?
5-When going to 4-speed on the floor, with a bench seat, how does shifter mount into,through floor?
6-What style fan shroud upper mount is used to hold it to core support?
7-Are the mechanical repro BB fuel pumps ok for a 450-475Hp engine?
That's all for now,as I'm sure ill have more info needed as I move along
Thanks again
Nick
Custom Cam /Engine Dyno and Spintron Operator at Brian Tooley Racing R@D
84 Mustang/Hertz Rent-a-Car
438CI 5.58@123 8.80@147 On Radials ALL MOTOR
Powered by my 13 year olds engine program
68 NOVA 396-375 HP F.A.S.T. Project
