Old 01-25-2016, 01:01 AM
Default Chevelle Camaro Corvette Nova NOS and rare parts
NOS 3969835 Holley Carburetor heat shield with NA9 option. $100
NOS 70-72 Camaro Console shift plate with automatic transmission $125
NOS 63-64 Corvette Fuel Injection emblems with unplated studs correct for NCRS judging $275
NOS Delco D 310 short tower distributor cap for Corvette fuel injection $250
NOS 1971 Chevelle Camaro and Nova TCS carburetor idle solenoid $75
NOS 69-72 Big Block starter heat shield GM # 361443 2nd design have 3 $75 each 1 left 2 SOLD
NOS 69-72 Starter Heat shield barrel nut GM part # 3943648 not repro $45 SOLD
NOS 65-69 Battery junction block correct short design GM part # 3905263 have 2 available $50 each SOLD
NOS 1970 TCS 4 speed transmission switch GM part # 3961567 correct pin type $75
NOS 1970 L34 and LS5 carburetor Decel Valve used on Rochester carburetor 7040205 very hard to find even used never mind NOS $400
NOS 1970
early production Chevelle radio static underhood ground strap GM # 3980141 $75 SOLD
1970 Camaro Z28 Holley carburetor list # 4490 dated 033 ( March 3rd week 1970 ) complete and correct un-modified carb perfect core $475 SOLD
1971 Camaro Z28 distributor part # 1112074 dated 0H11 ( August 11, 1970 ) nice core guaranteed original not a restamp $375
NOS 1971 Chevelle LS6 distributor part # 1112054 dated 0G27 ( July 27, 1970 ) Really cool piece of LS6 history, produced in anticipation of 71 LS6 production which never ended up being a reality for Chevelles in 71. For the serious LS6 collector $750
NOS 1971 Chevelle SS grille emblem GM # 3991036 $65
NOS 65-72 Air Cleaner spark arrestors with GM stamping. GM # 3849856 have 2 available $60 each
NOS 67-69 Camaro Chevelle Nova and Passenger car spare tire lock assembly GM # 987048 have 2 available, 1 is complete the other is missing the J hook and instruction sheet ( just re-use your original J hook ) $80 for the complete kit or $40 for the one missing the J hook and instruction label. Both SOLD
New 1970 Big Block engine lift brackets with part # 3969829 part # front hook and L marked rear bracket. These are new reproductions reproduced by me with correct fonts and features copied from originals. $70 pair
Nice used upper alternator bracket for 69-74 small block Camaro, Chevelle and Nova. Nice clean undamaged piece $45
NOS GM hi-perf smog pulley GM part # 3932458. This is I believe an early product of ASL corporation that they part numbered using a GM ink stamped pulley when they were available 20? or so years ago. Next best thing to an assembly line part at a fraction of the cost. $275 SOLD
Reproduction 3932458 Smog Pulley new but has shelf wear $40
I can email pictures of any parts you may have interest in.
Thanks, Chris
