Old 01-18-2016, 07:46 PM
68moz28rs's Avatar
68moz28rs 68moz28rs is offline
Default 67 68 Camaro Nova Hurst Shifter Rods Levers And Mount
I have a Hurst shifter for a muncie, Not Original, but not cheaply made new stuff. I know it fits 67 and 68 Camaro and Nova With or without Console but it fits more that I don't know of off my head. Chrome isn't perfect but it's decent. It's slightly pitted but nothing you can't get out or just get the stick rechromed. Needs some Bushings and Clips. Comes with Original bolts that go through the shifter. Has a vintage Hurst T handle on it. The mount Is the u-bolt style. Here are the numbers:
273902 stamped on front with 2083 comp. Plus body
6836 Handle
2445 Reverse Lever
5287 & 5286 1/2 3/4 Levers
5307 3/4 Rod
2145 1/2 Rod
3691 Reverse Rod
$400 obo for everything
68 Camaro 302 Z/28 Rally Sport
68 Camaro Convertible w/427
68 Camaro Drag Car
67 Camaro Royal Plum RS/SS
67 Camaro Convertible 327 RS
92 Corvette Convertible Quasar Blue white top
http://www.ebay.com/sch/usa-1musclec...pg=&_from=
Old 01-19-2016, 02:11 AM
68moz28rs's Avatar
Default Re: 67 68 Camaro Nova Hurst Shifter Rods Levers And Mount
68 Camaro Drag Car
Old 01-19-2016, 03:57 AM
1967Z28's Avatar
1967Z28 1967Z28 is offline
The 273902 shifter body and 6836 handle are for fullsize Chevy but the other pieces are correct for both fullsize Chevy and Camaro/Firebird. The correct 60's era Camaro shifter body is 150043 and the handle is 4106. You have a correct 60's era shifter for a fullsize Chevy. Very cool item.
Old 01-19-2016, 05:52 AM
68moz28rs's Avatar
Thanks for The info, I wasn't sure what it was for because it's Out of a 67 Camaro with a console. I know it fits but maybe it's not for it specifically. Hurst says the handle is for 70-72 Camaro not 60s that's my bad. But as for the shifter I've never seen that number before.
68 Camaro Drag Car
Old 01-20-2016, 10:48 AM
JoeC JoeC is offline
The 273902 shifter body number is a serial number that was used on the early shifters.
Hurst later changed to a shifter ID number 391-xxxx
Old 01-20-2016, 06:27 PM
69biscayne 69biscayne is offline
Is this shifter for a 66/67 or 68/69 full size car?
Thanks, Steve
Old 01-20-2016, 06:44 PM
68moz28rs's Avatar
Fits 1968-70 Full Size Chevy w/muncie
Brandon
68 Camaro Drag Car
Old 01-22-2016, 12:41 AM
the trans levers fit Muncie 63 to 68 small slot with stud
Muncie 69 to 74 used the longer slot and bolt
Old 01-22-2016, 01:50 AM
68moz28rs's Avatar
I was going by what the shifter fits, not the levers.
68 Camaro Drag Car
Old 01-22-2016, 02:14 AM
68moz28rs's Avatar
Did some research. Shifter fits 68 Nova without console Only.
68 Camaro Drag Car
