Old 01-10-2016, 10:06 PM
green crv green crv is offline
Default Harrison radiator
Does anyone know what a CV code on a four core standard shift Harrison radiator was used in ? [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Old 01-11-2016, 06:13 AM
Kurt S Kurt S is offline
Default Re: Harrison radiator
No.
But some codes near that are full-size.
Kurt S - CRG
Old 01-12-2016, 03:39 AM
mssl72's Avatar
mssl72 mssl72 is offline
The CV was a full size code, 1966 L36 427/390hp (non-A.I.R.), manual trans, part number 3007718. Later replacement part number was 3012619. Does the &quot;horse collar&quot; have the part number stamped in it?
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 01-12-2016, 05:00 AM
carnut4life carnut4life is offline
My 72 4 speed TA has a CV coded code stamped on the passenger side tank of the radiator. Believe 71 Firebirds used the same tank as well.
Old 01-12-2016, 03:14 PM
Tarrytown SS427s Tarrytown SS427s is online now
Any pictures?
Steve
68 Caprice Estate
68 Camaro SS396 4 speed
Old 01-12-2016, 09:17 PM
mssl72's Avatar
Interesting... Does it have top and bottom tanks or side tanks? Is the CV stamped into the tanks or is it on a tag?
Mark
Old 01-13-2016, 01:18 AM
My radiator has side tanks, CV on the passenger side and IA on the drivers side and both are stamped on the tag as well. My radiator tag has a FN on it since it doesn't have a/c, believe the a/c and HD cooling cars had a FH tag with the same CV and IA tanks.
Old 01-13-2016, 07:16 AM
mssl72's Avatar
Hey, green crv! Does your radiator have side tanks or top/bottom tanks??
Mark
Old 01-15-2016, 02:08 AM
Hi guys, thanks for the information. First there's no numbers on the horse collar, it has side tanks with CV and A 3 on the pass side. Theirs no tag. Had a recore done in 1984 and I am still using it. Just wondered what it was from. Thanks Steve. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 01-15-2016, 07:13 AM
mssl72's Avatar
So if it's got side tanks and the CV is stamped into the tank, it's most likely not a full size '66 radiator. Probably what carnut4life was mentioning.
Mark
