Old 12-13-2015, 05:43 PM
resto4u resto4u is offline
Default *WANTED* 73 Z28 ENGINE OR BLOCK CLK
Wanted 73 z28 engine or block suffix CLK MUST BE ORIGINAL, NO RE-STAMPS. Thanks,Roger
Old 12-14-2015, 12:14 PM
lbnaz lbnaz is offline
Default Re: *WANTED* 73 Z28 ENGINE OR BLOCK CLK
Hello, I have a CLR its a 73 L82 out of a Corvette if interested complete long block. Thanks, Larry
Old 12-15-2015, 03:26 AM
copo69's Avatar
copo69 copo69 is offline
I've got a CLK short block that I'd sell.
Old 12-16-2015, 11:33 PM
copo69 i sent you a pm.
Old 12-18-2015, 02:16 AM
LITTLE TOMMIE LITTLE TOMMIE is offline
i have a complete 73 z28 motor but it is stamped V0312CLJ
Old 12-18-2015, 01:19 PM
Woj's Avatar
Woj Woj is offline
In case you haven't seen this already, not mine:
http://cleveland.craigslist.org/pts/5346365062.html
I am doing an LS engine swap in a 73 Camaro Z/28. I am replacing engine, trans exhaust radiator fuel tank and everything thats bolted on the engine. Also have all smog related components that are the same for any 69-73 small block chevy engine. If your doing a period correct restoration. Engine ran fine car has 80k miles. It leaked a little oil but engine runs strong. Trans is a Muncie M-21 4 speed. Also have shifter. These are all orig. parts. The engine code is CLJ. It's a four bolt main. Heads are double hump 202 heads. Carburetor had a rebuild a little more than a year ago and clutch was replaced at that time. Engine complete carb. to pan and trans inc. bellhousing clutch and shifter $2500
contact name:
Rick
call or text:
☎ (440) 610-4098
reply by email:
[email protected]
Old 12-18-2015, 11:25 PM
Thank you everyone for the help. keep em coming ! i might have one, but we are still working a deal.
