Old 11-14-2015, 09:57 PM
Enoch Enoch is offline
Banned
Default 69 70 L72 L78 LS6 L89 Engine hardware kit
Complete original 69 70 Chevelle Nova Camaro 396 + 427 + 454 engine hardware kit. Every nut bolt screw washer is 100% assembly line correct and original.
Included are:
1. 14 A flathead flanged intake manifold bolts.
2. 16 exhaust manifold mounting bolts, 8 X flanged head locking bolts, 8 non flanged head non locking thread bolts 4 C + 4 CH.
3. 3 WB crankshaft pulley mounting bolts and lock washers.
4. Thermostat housing mounting bolts 660. 1 C + 1 RBW.
5. 4 L8 fan clutch to water pump of mounting bolts and lock washers.
6. 2 E coil bracket to intake manifold mounting bolts.
7. 10 L timing chain cover mounting bolts.
8. 20 L oil pan side rail mounting bolts, and 2 EL oil pan front corner mounting bolts.
9. D oil pan drain plug.
10. 4 C water pump to block mounting bolts.
11. Smog pump and bracket mounting hardware, 1 long RBW pivot bolt, 2 TR + 1 CH bracket mounting bolts, 3 RBW pulley mounting bolts and lock washers and 4 []
Case bolts and lock washers.
12. C stamped distributor hold down bracket and WB mounting bolt.
13. 4 A transmission 2 bell housing mounting bolts and lock washers.
14. 6 EWF bellhousing to engine block mounting bolts.
15. 2 TR short + 2 TR long transmission mount mounting bolts lock washers special thick flat washers.
16. FLAG inspection cover mounting bolts.
825.00 shipped to the lower 48.
Old 11-14-2015, 10:18 PM
bbbentley's Avatar
Default Re: 69 70 L72 L78 LS6 L89 Engine hardware kit
Nice grouping of hardware Rich. No valve cover TR's?
FULL OWNER HISTORY
Old 11-14-2015, 10:19 PM
Banned
I forgot to include them it would either be the large font Tr or the small font TR depending on what time the car was built
Old 01-25-2016, 08:27 PM
Banned
This set sold made a new sex same headmarkings 1,200
