Old 11-14-2015, 02:20 AM
Enoch Enoch is offline
Banned
Default 65 66 67 396 427 Engine/Trans Hardware Kit
This is a complete set of ORIGINAL ASSEMBLY LINE CORRECT ENGINE + TRANSMISSION HARDWARE for 65, 66 and 67 396 and 427 Corvettes, Camaros, Chevelles and Impalas.
Included are :
1. 16 M Intake manifold mounting bolts.
2. 16 O Exhaust manifold mounting bolts.
3. 20 L Oil pan side rail bolts + 2 L oil pan front corner bolts.
4. A oil pan drain plug.
5. 10 L timing cover bolts.
6. 6 RBW engine mount to block mounting bolts.
7. 2 F motor mount to frame through bolts, 4 Special flat washers + 2 mardsan nuts.
8. 3 TR + 1 AIR stud water pump mounting bolts.
9. 4 (((EL))) Inspection cover bolts.
10. 1 RSC distributor clamp mounting bolt, wire clamp and plate.
11. C + RBW Thermostat housing mounting bolts.
12. 2 B&H fuel pump mounting bolts.
13. 2 E flanged head coil bracket mounting bolts.
14. 1 coil bracket screw.
15. 3 RSC Crankshaft pulley mounting bolts + lock washers.
16. 4 AS Fan Clutch to water pump hub mounting bolts + lock washers.
17. O balancer bolt, lock washer + large washer.
18. 4 TR Transmission to bellhousing mounting bolts.
19. 6 RBW Bellhousing to block mounting bolts.
20. C stamped vacuum advance clip.
21. Original vacuum advance white strip hose.
22. 14 RBW Valve cover bolts. ( if you have a 65 or mid 66 I will include 3/8 hex head are RBW bolts, if you have mid 66 through 67 I will include RBW bolts with a 716 Hex.
23. RBW, TR TRANS MOUNT BOLTS AND WASHERS
1600. Shipped to the lower 48.
