Old 11-12-2015, 02:18 AM
Enoch Enoch is offline
Banned
Default 69 70 71 396 427 454 Engine bolt kit
69 70 71 396 427 454 Camaro Chevelle Impala 69-70 Nova Engine bolt kit. ALL ORIGINAL ASSEMBLY LINE CORRECT, UNRESTORED.
Included are:
1. CP flat head w/thick flange intake manifold bolts.
2. 16 C exhaust manifold bolts, 8 flanged head w/locking threads, 8 non flanged regular thread.
3. 10 L timing cover bolts.
4. 20 L oil pan side rail bolts + 2 L oil pan front corner bolts.
5. 4 C water pump to block bolts.
6. 2 E coil bracket bolts.
7. C stamped flat distributor clamp + RSC bolt.
8. 4 AS fan clutch to water pump hub bolts.
9. 2 RBW (correct short length) Fuel pump bolts.
10. Not pictured but will be included 14 TR valve cover bolts. Depending on if you have an early 69 I will include small font bolts or if you have a mid 69 to 71 I will include large font TR bolts. SOLD
800.00 shipped to the lower 48. SOLD
