Old 11-10-2015, 02:45 PM
Crossbreed383 Crossbreed383 is offline
Default Matching / Applying color to repro dash pad
Need to match the oem color on a new pad.
Old pad is green, and new one is black as delivered
Any tips or procedures would be appreciated
Thanks
Custom Cam /Engine Dyno and Spintron Operator at Brian Tooley Racing R@D
84 Mustang/Hertz Rent-a-Car
438CI 5.58@123 8.80@147 On Radials ALL MOTOR
Powered by my 13 year olds engine program
68 NOVA 396-375 HP F.A.S.T. Project
Old 11-10-2015, 04:13 PM
Alss's Avatar
Alss Alss is offline
Default Re: Matching / Applying color to repro dash pad
colors can be made to match existing. year make model?
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 11-10-2015, 04:47 PM
73 Buick Apollo
Needs to be green
Old 11-10-2015, 07:57 PM
m22mike's Avatar
m22mike m22mike is offline
See if you can find a paint store that has a SEM mixing system. There is one here in Canton Ohio that has helped me out.
Mike
Old 11-10-2015, 08:02 PM
Thanks
Was actually hoping someone who has done it would give me actual tips for cleaning/application.
I think i have a resource for the materials
Sorry
Nick
Old 11-10-2015, 08:14 PM
m22mike's Avatar
Clean the crap put of it with with HOT soap and water, maybe even 409 or simple green first. And use some vinyl adhesion promoter, should be able to find a good aerosol product at your local paint supply.
Old 11-12-2015, 10:23 AM
kwhizz kwhizz is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: m22mike</div><div class="ubbcode-body">See if you can find a paint store that has a SEM mixing system. There is one here in Canton Ohio that has helped me out.
Mike </div></div>
x 2........................Make sure you use the SEM prep solvent before applying the dye......
Ken
Old 11-12-2015, 08:55 PM
Alss's Avatar
clean is the key!!
Old 11-12-2015, 09:45 PM
And when you are done cleaning it, clean it again! If there was ever any Armor All applied, good luck.
Old 11-13-2015, 09:45 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SS427</div><div class="ubbcode-body">And when you are done cleaning it, clean it again! If there was ever any Armor All applied, good luck. </div></div>
Its brand new in the box ,so fingers crossed its still a virgin lol
