Old 11-09-2015, 02:38 PM
Enoch Enoch is offline
Banned
Default M 66-68 Corvette Chassie Hardware kits
complete original unrestored set of Survivor Chassis hardware for M-66, 67 and 68 Corvettes. THIS IS EVERY NUT, BOLT, WASHER & LOCK WASHER NEEDED TO ASSEMBLE YOUR CHASSIE. Every piece is assembly line correct. You won't find a set like this for sale anywhere else. 30 plus years of experience has helped make this 100% correct.
Included in this set are:
1. RBW front sway bar bushing retainer 2 frame bolts + nuts.
2. Lower A-Arm 2 frame front WB mounting bolts + N stamped nut plates + lock washers..
3. Lower A-Arm 2 frame rear WB mounting bolts, lock nuts and serrated washers.
4. Lower A-ARM [] Bushing retainer bolts & lock washers.
5. Lower A-Arm F bumper mounting bolts + nuts.
6. Upper A-Arm RSC Bushing retainer bolts + lock washers.
7. Upper A-Arm 2 frame mounting studs. (These are unique to mid 66-68 Corvettes) and lock nuts.
8. RBW front shock Mounting bolts, over sized retainers + extra tall nuts.
9. RBW Steering box 2 frame carriage bolts, lock washers + nuts.
10. RSC Steering box cover bolts + lock washers.
11. RSC/RBW Idler arm mounting bolts + lock washers.
12. A Tie Rod end clamp bolts + lock nuts.
13. 5/8" Hex nuts.
14. Spindle 2 knuckle M bolts + lock nuts.
15. Upper spindle mounting bolts M.
16. P transmission mount to bracket bolts + RBW
17. Transmission mount bracket 2 frame bolts U, WB, TR, lock nuts + washer.
18. WB pinion snubber bracket front bolt, washers, lock washer + copper plated nut.
19. M + P pinion snubber bracket 2 rear bolts, washer, lock washer hex nut + castle nut.
20. WB center leaf spring mounting bolts +lock washers.
21. C outer leaf spring mounting bolts, flat washers + castle nuts.
22. WB rear crossmember to rear end housing mounting bolts + flat washers.
23. WB rear crossmember 2 frame mounting bolts + lock washers.
24. WB strut rod bracket 2 rear mounting bolts, lock washers + flat washers.
25. WB gas tank brace 2 frame mounting bolts, lock washers, flat washers + nuts.
26. O rear end cover to rear housing bolts + lock washers.
27. M camber adjusting bolts, eccentric washers, bushing caps, lock washers + nuts.
28. L5 rear upper shock Mounting bolts, lock washers + nuts.
29. Rear lower shock Mounting nuts \W/ + lock washers.
I also have sets
for 63 chassis, 64 Chassies, 65 through mid 66 chassis, and 69 through 74 Chassies. Any questions contact me.
4500.00 per set
3 sets of 66-67 available
