Old 11-01-2015, 01:52 PM
XXXGoldL34M20's Avatar
Default Various Nuts & Bolts Etc... all in 1 Listing
Rather then do separate listings of over 2000 Bolts & Nuts that I have in stock I will start to list numbered groups and describe each part the best I can. If anyone needs close up pictures just contact me and I will gladly send any photo you like. Shipping will be extra depending on weight, so the more you buy the better the shipping rate will be on average. Shipping will be exact charges and any over charges will be refunded if I see my estimate is over priced when mailed at the post office.
1-Fender Clip-Bolt &quot;LC&quot; mark $5 Each <span style="color: #FF0000">*SOLD*</span>
2-NOS Petcock to Radiator Bolt $5 Each <span style="color: #FF0000">*SOLD*</span>
3-Bumper Bolt $5 <span style="color: #FF0000">*SOLD*</span>
4-Suspension Bolt &quot;LC&quot; mark with lock nut &amp; cotter pin $15 <span style="color: #FF0000">*SOLD*</span>
5-Steering column to Shaft Retainer with Bolt &amp; Nut &quot;WB&quot; Mark $15 <span style="color: #FF0000">*SOLD*</span>
6-Water pump bolts &quot;WB&quot; mark other two I can't identify $5 Each <span style="color: #FF0000">All 3 are</span> <span style="color: #FF0000">*SOLD*</span>
7-Rear Trunk Release Screws &quot;S&quot; mark $5 Each <span style="color: #FF0000">*SOLD* </span>
8-BB fuel pump bolt &quot;E&quot; mark $10 <span style="color: #FF0000">*SOLD*</span>
9-Inner fender to Retainer bolt &quot;S&quot; Mark $10 <span style="color: #FF0000">*SOLD*</span>
10-Power Steering Pulley Nut $5 <span style="color: #FF0000">*SOLD*</span>
11-Alternator pulley nuts &quot;BT&quot; mark $10 unmarked $5 Both <span style="color: #FF0000">*SOLD*</span>
12-Radio Tune pole nuts $5 Each <span style="color: #FF0000">*SOLD*</span>
13-SB Distributor hold down bracket $5 Flag Nut/Washer $10 <span style="color: #FF0000"> Both Are *SOLD*</span>
14-Nos Front emblem speed nuts $10 bag <span style="color: #FF0000">*SOLD*</span>
15-Reverse Lock Out Bracket to frame bolts &quot;Unmarked&quot; $15 set <span style="color: #FF0000">*SOLD*</span>
16-Steering shaft rag joint bolts &quot;L5&quot; &amp; &quot;N&quot; marks $5 Each <span style="color: #FF0000">*SOLD*</span>
17-Battery Tray to Inner fender under bolts &quot;S&quot; or &quot;E&quot; Markings $10 each <span style="color: #FF0000">Both Are *SOLD*</span>
18-Flywheel to Crankshaft Bolts &quot;P&quot; mark $5 each
19-Rear end cover bolts &quot;E&quot; mark $5 each <span style="color: #FF0000">*SOLD*</span>
20-Rear Fender Bolts with Washers, two are &quot;E&quot; marked, one is &quot;LF&quot; and one is &quot;N&quot; $10 Each <span style="color: #FF0000">*SOLD*</span>
I have many other bolts and nuts coming up. It is time to clear this stuff out of my garage.
Old 11-01-2015, 03:37 PM
427yenko 427yenko is offline
Default Re: Various Nuts & Bolts Etc... all in 1 Listing
I will take number 13 (sb distributor hold down with flag bolt and washer), and number 17 (battery tray to inner fender under bolts (quantity 2) marked S). Thanks
Old 11-01-2015, 08:11 PM
L78 Fred L78 Fred is offline
I will take # 8 and # 6
Thank you
Fred
Fred
[email protected]
610-585-4155
WANTED:
Old 11-02-2015, 01:42 PM
Danny, you show &quot;16-Brake backing bolts &quot;L5&quot; &amp; &quot;N&quot; marks $5 Each&quot;. Those look more like rag joint bolts to me but I could be wrong. Just wanted to clarify if you made an error.
Old 11-02-2015, 05:25 PM
Danny,
I'm with Rick on #16 being for the steering shaft rag joint. FWIW.
Chris
Old 11-02-2015, 05:54 PM
jl8z28 jl8z28 is offline
Yenko Premier Member
Get AMk s catalog you can find what most of the bolts are in there
