Old 11-01-2015, 04:49 AM
JEFF GHILANI JEFF GHILANI is offline
Default LS6 SW reduction gear & fuel line bracket
<span style="font-weight: bold">1970 Chevelle Camaro LS6 Speedo Reduction Gear</span>
Stewart-Warner speedometer adapter with the .8241 reduction ratio that is correct for certain 1970 Chevelles and Camaros. Chevrolet Part # 3950352. Correct style original that works great. It is correct for several applications including all LS6 Chevelles (M22 and M40) with 4:10 ratio rear axle. There are some other applications for this part. Don’t assume you don’t need it. Not all of these had the application reference code. This one does. Code C (.8241C). Check your build sheet in box 92. Look for the letter “C”. If you don’t have a build sheet, check your speedo gear chart in the old Chevrolet part number books if you have them. Not the prettiest one in the world but it works perfectly.
<span style="text-decoration: line-through">$200</span> $100.00
<span style="font-weight: bold">1970 Chevelle Camaro Nova LS6 L78 Fuel Line Bracket ORIGINAL</span>
This is an original with the part number stamped into it. Repros do not. Someone drilled an extra hole in it.
$495
