Old 10-31-2015, 02:26 PM
69 Post Sedan's Avatar
Default 1969 12 Bolt 4 Series Posi Unit 30174
I have a used 1969 4 series 12 bolt posi unit. It was cast on the 101st day which is April 11th. I believe that the "J" makes it a 1969 and the "E 29" makes it machined May 29.
This unit is for 12 bolt passenger cars with 30 spline axles, 8.875'' Diameter Ring Gear.
Since it is used, I would have it completely gone through.
$275
I also have set a very hard to find of 1969 dated 4.10 gears. Ring part number is 3862526 dated 3/69 and the pinion part number is 3862514 dated 4/69.
They do have some pitting on the teeth but I've talked with a few people who said that they will work fine although they may howl at certain speeds. Most definitely should be fine for a car that isn't driven a lot.
<span style="color: #FF0000">SOLD</span>
I have the factory correct bolts for the ring gear. $30
I will sell this as a package deal.
I can ship at the buyers expense.
Thanks SYC, Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
