Old 10-26-2015, 03:30 PM
Default 455 HO Engine WC Code 4Spd
Looking to see if someone out there has this 1971 Trans Am or Formula car before I sell the engine to a GTO guy for his project.
Complete engine minus carb and intake manifold. The engine is standard bore and runs but has a slight noise / knock.
VIN: 1N110295
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
2019 Corvette Grand Sport
68 SS Lemans Blue
69 RS/Z28 Maroon JL8
66 Corvette Ermine White L75
Old 10-26-2015, 04:14 PM
tjs44 tjs44 is offline
Default Re: 455 HO Engine WC Code 4Spd
You might post on the PY board!Tom
Old 10-26-2015, 05:14 PM
Go here and post. Lots of guys there with these cars:
http://forums.maxperformanceinc.com/...play.php?f=437
Good luck!
Old 10-26-2015, 05:30 PM
Thanxs Steve....Dave
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
68 SS Lemans Blue
Old 10-28-2015, 11:21 AM
Tracker1's Avatar
Tracker1 Tracker1 is offline
He wants to put it in a Goat? Aw, too bad, many 1971 TAs out there without their original engine - this would be great for somebody's HO Firebird engineless project.
I ain't nobody, dork.
Old 11-24-2015, 12:30 AM
The Boss's Avatar
The Boss The Boss is offline
Likely came out of a Formula - the WC code was the Ram Air code which was also used in the GTO. Although they would occasionally show up in TA's the TA was not considered a Ram Air application and had different carb numbers as well.
Some guys they just give up living
And start dying little by little, piece by piece,
Some guys come home from work and wash up,
And go racin' in the street.
Bruce Springsteen - Racing In The Street - 1978
Old 11-28-2015, 09:11 PM
68bird400HO 68bird400HO is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: The Boss</div><div class="ubbcode-body">Likely came out of a Formula - the WC code was the Ram Air code which was also used in the GTO. Although they would occasionally show up in TA's the TA was not considered a Ram Air application and had different carb numbers as well. </div></div>
Actually, that is not correct. Ram-Air and non-Ram-Air used the same block codes. In 71 there were 3 455HO block codes, WC (455HO with M22), WL (455HO with 3-speed manual (yes there were a few built)), and YE (455HO with Th400). In 72 they had 4 455HO block codes, an auto and manual trans version for each &quot;with&quot; and &quot;without&quot; unitized distributor.
Old 11-28-2015, 09:19 PM
BTW, the engine actually came out of a Formula. Sadly, it was parted out and sold off. The &quot;N&quot; in the VIN denotes it was a Norwood Assembly Plant engine. Normwood only built Firebirds and Camaros.
Old 11-29-2015, 03:21 PM
Too bad to see an HO formy die. Did you know the car?
As far as the RA vs nonRA codes from above, Boss was confusing the block coding with the carbs. In 71, there were 4 carb #s, manual and auto x RA and nonRA. The TAs were considered nonRA but in a few random documented cases got a RA carb. Probably just a situation were the nonRA carbs were out and they needed to keep the line moving. Not really sure what the functional difference is between the RA and nonRA versions.
Old 11-29-2015, 03:49 PM
I traded PMs with the original poster. Very sad - it was a Black car. Uber rare color in 1971.
