Old 10-21-2015, 08:30 PM
Edgemontvillage's Avatar
Edgemontvillage Edgemontvillage is offline
Default 1969 Camaro Center / Drag Link - LOCATED
[size:11pt][font:Arial]Looking for a nice, original center link / drag link without corrosion damage for a Power Steering equipped 1969 Camaro. Center to Center measurement is 28.5&quot; and the bar diameter is 1 1/8&quot;. <span style="font-weight: bold">Located, thanks SYC !</span>
Reference photo:
Old 10-22-2015, 01:56 AM
enio45 enio45 is offline
Default Re: 1969 Camaro Center / Drag Link
PS is different than manual?????
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 10-22-2015, 03:13 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: enio45</div><div class="ubbcode-body">PS is different than manual????? </div></div>
The Power Steering center link spec for 1969 is 1 1/8&quot; (1.125&quot diameter, PN 3953221, and the Manual Steering link spec is 0.95&quot;.
Old 10-22-2015, 04:16 PM
so it is the diameter diff - not the length or hole placement.
wonder why?? This obviously did not know - might need to find one for my self as well!!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 10-22-2015, 06:27 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: enio45</div><div class="ubbcode-body">so it is the diameter diff - not the length or hole placement.
</div></div>
No other differences except the bar's 1 1/8&quot; diameter. I included the center to center measurement in my initial wanted post just in case an SYC Member had a center link and wasn't sure if it was for a 69 Camaro, its another data point.
Old 10-23-2015, 03:53 PM
chris69 chris69 is offline
PM sent.
Old 10-24-2015, 12:09 PM
BARRY BARRY is offline
i will check i think i have
Barry Allan
Old 10-25-2015, 01:45 PM
DEUCE DEUCE is offline
I have a complete Power Steering set-up still on a Ca. subframe.
Mike
Old 10-25-2015, 03:05 PM
Mike, thanks for your reply, I have a complete PS assembly except a drag link (which I located today) and an original coupler / rag joint. <span style="font-weight: bold">If you are able to part with the coupler/rag joint I would be very interested.</span>
Lloyd.
