Old 10-05-2015, 08:23 PM
AMANOCC AMANOCC is offline
Yenko Premier Member
Default 1969 Camaro and others small stuff
1. Clutch Z-bar bracket GM piece blasted and painted correct for 68-69 $35.00 Sold one, I have one more,
2. 68-69 Rear brake line bracket, nice condition. $35 Pending
3. 69 Front brake line bracket for disc brakes, passenger side, super nice original bracket. $25 sold
4. Camaro rear end brake like bracket correct for 68-69, 10 or 12 bolt. Very nice condition, complete with R-S-C head marked bolt (phosphated), bracket has "V" stamp and has been blasted and painted. $40 Might have the same piece for chevelle, let me know if you need it, i believe it's a bit longer? Pending
5. Small block lift hook looks like "L" stamped into it, super condition $15.00
6. 69 Factory Hurst shifter mount bracket bolts, nice $12.50 each, I do have three total. Pending
7. BB starter brace GM original $15 sold
8. Original p/s pump nut to secure the pulley. $15
9. 65 66 67 big block (non solid lifter applications) PVC retaining clip, original piece, small crack by bolt hole, should be fine once a bolt is installed. $50 Sold
