Old 09-30-2015, 05:17 AM
Vortecpro Vortecpro is offline
Default 1969 L78 396 375 HP Dyno Test
Thought some might be interested in this build: factory 1969 L78 396 375HP. 3.760 stroke std, 4.134 bore, Speedpro L78 pistons, sealed power moly rings, resized 3/8 dimple rods, factory L78 oil pump, factory oil pan, factory GM card board tube L78 L72 cam, installed @ 108, isky lifters, factory pushrods, factory rocker arms. 4.250 bore steel shim head gaskets, factory M head bolts, 840 heads, bronze guides, race valve job, CCs set to 108, factory 163 intake along with the factory L78 carb, factory L78 points dist setup by Harold Bettes. Tested with 2 inch headers into 3 inch mufflers, gas used was VP C-12. Basically very close to a factory L78.
Corrected HP
4500 379.8
4600 382.3
4700 385.5
4800 389.8
4900 395.2
5000 406.3
5100 415.3
5200 423.4
5300 431.4
5400 438.6
5500 444
5600 446.5
5700 451.7
5800 452.3
5900 451.2
6000 453.9
6100 454.9
