Old 09-03-2015, 12:43 AM
Spooky's Avatar
Spooky Spooky is offline
Default original brake drums?
Hello there, I was wondering if anybody here knows anything about original brake drums. I have a matching pair that are dated the same. one has a 40 stamp on it and one has a 41 stamp. they look to be opposite from each other. Is it rare to be dated? could they have been NOS at one time? I would not think so due to the same date. Thank you for any insight you can give.....
Scott
69 Camaro RS/SS X22 4speed NOM but working on something special
69 Camaro x11 355 crossram m22 12 bolt 3.73's
Old 09-03-2015, 10:09 AM
bergy's Avatar
bergy bergy is offline
Default Re: original brake drums?
All MVSS (motor vehicle safety systems) items were required to have manufacturer's date codes on them. The "T" designates Tonawanda Foundry. If it was "W" it would designate Whelen Foundry (non GM foundry in Chattenooga that supplied about 50% of these drums). The "40" and "41" are mold insert numbers. Cast on second shift - mold line 8.
Old 09-03-2015, 09:32 PM
Spooky's Avatar
Thanks for the info! The only ones I have ever seen have not had dates on them. Are they worth more because of the matching dates?
Scott
Old 09-04-2015, 03:17 AM
Woj's Avatar
Woj Woj is offline
My survivor Chevelles and Camaro have similar markings with dates.
Thanks for the good info Bruce.
Phil Woj.
Old 09-05-2015, 02:22 PM
novadude novadude is offline
Do these original drums have any value? I've got three spares that I had blasted. They don't appear to have ever been cut, but I've not measured yet.
Old 09-06-2015, 04:46 PM
Spooky's Avatar
What would the stock uncut measurement be?
Old 09-06-2015, 05:13 PM
The factory spec is 9.5 inches. Fronts are 2.5 wide (actually the shoe is 2.5, but the drum is a bit wider for clearance) with the rears being 2 inches wide.
I have measured some uncut drums that come in just UNDER 9.5, but usually pretty darn close.
Max diameter is 9.560, or .060 oversize. If you go that far over, you really need special shoes that are oversize to get a good fit.
Old 09-09-2015, 02:53 PM
Day2_69Z Day2_69Z is offline
Original Equipment Drums.
Those look nice.
Old 09-09-2015, 11:12 PM
Unreal Unreal is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: bergy</div><div class="ubbcode-body"> If it was &quot;W&quot; it would designate Whelen Foundry (non GM foundry in Chattenooga that supplied about 50% of these drums). </div></div>
Wheland Foundry was a huge 24/7 3 plant facility when I moved here in 89. Sadly, it is nothing but a bulldozed EPA nightmare now.
