Old 08-04-2015, 08:46 AM
Default Sheet metal around valve spring ?
Hi,
last weekend a took apart a 230 hp 454 from a 1987 motorhome. Around the valve springs on the "peanut port" heads there is a sheet metal part I have never seen before. What´s the purpose of this ?
This 454 had a 4-bolt block (14015445), cast crank, cast pistons, and peanut port heads. It is the third 4-bolt 454 from the late 80´s I have taken apart with small plugs above the oil filter.
Anders Stålklint.
